2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
What’s the purpose of this metal plate covering the trackpad?
Does this metal plate serve to dissipate heat or something? Because the only thing on the other side of it is a battery, and I can’t see how it would short anything
Score 1
1 Comment
The small screw attached to the plate is very difficult to remove!
by
Add a comment
1 Answer
Most Helpful Answer
It’s important!
When correctly mounted it offers a bit more structure rigidity (case torsional twist) as well as offer structure for the battery. It also helps in controlling debris and liquid entry and lastly helps control the air flows as you don’t want air leakage to areas that don’t need cooling.
Please put it back!
Score 2
1 Comment:
Took the words right out of my mouth.
by
Add a comment
Add your answer
rickcostel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 72
