All-in-one inkjet printer, copier, fax and scanner with wireless home or office advantages.
14 Questions View all
Why is there a white line through copied documents.
All documents copied have white line through the text on the right side--the printing fades so much that it is almost illegible. Whereas all printed documents are crisp and clear.
Add a comment
Your printer actually has two separate systems incorporated into one box; a scanner that converts printed images into digital information, and the printer that does the opposite, converting digital information into a printed copy.
By verifying that a document that comes in digital form prints correctly, that tells us the printer part is working and that the problem lies in the other half of the system, the scanner.
For most multifunction printers, the scanner consists of a bar that has two components built into it; a scanning element that pics up a single line of pixels the full width of the document, and a light source usually on the same bar that illuminates the document so the scanning element can pick up the image.
One other check you can do is to compare the image between one that's placed onto the document glass and scanned vs. one that's fed via the Automatic Document Feeder. The two scans work differently; in the first case the scanning bar is physically moved the length of the paper, while the scanning bar stays stationary when the ADF is used.
If there's a difference in what you see using the two different scanning methods, then you'll be looking at the glass for any kind of obstruction when the scanning bar is in its parked position. Otherwise check for any LEDs on the scanning bar that are out and any kind of dust, dirt or lint that might be obscuring part of the scanning head.
The other place to check would be the flexible cable that connects the scanning head to the rest of the printer; over time with the movement of the scanner that connector could crack or work its way loose.
I'd say check those things then come back and let us know what you found and we can go from there.
2 Comments:
I don't know where the LEDs on the scanning bar are located! And I don't know where the flexible cable that connects the scanning head to the printer is located!! Actually what I need is the specs (diagram) of the Brother MFC 6490-CW printer!! To date I haven't been able to find them on the web or at the Brother site! Thank you anyway!!
by
@kclooking Well, the LEDs will be easy to find; just start a scan with the lid open and you'll see them light up across the width of the scanning bar. If any of them are out, you'll be able to note a gap in the light coverage.
I'm afraid I don't have any documentation either, but it's possible some of our other contributors may know where to find it now that we know what you're looking for.
by
Add a comment
Good afternoon everyone. Recently I was faced with the need to draw up a document called an affidavit and fell into a stupor. Internet searches led me to a useful site - with a detailed explanation of the use of an affidavit, writing the correct format of this document and areas of application. This way I was able to use a standard free affidavit template and saved time. I encourage you to read this incredibly useful blog too.
Add a comment
Add your answer
KClooking will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 61
