A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
171 Questions View all
pc artifacting, not sure what to do
hi everyone, i am a first time pc builder and i have had my pc for a couple of months now. everything has been running smoothly until i recently started getting gpu artifacts all over my screen. im not sure how to fix this and i dont wanna cause any damage to my internal components
Update (07/11/23)
just thought id add my specs
gpu- rtx 3090ti msi suprim x
cpu- intel i12900k
motherboard- ASUS Intel Z690 ROG STRIX Z690-E
Update (07/25/23)
@oldturkey03 @jayeff i have updated my drivers and after doing that ive had no issues
Score 1
5 Comments
@callumventer " gpu artifacts all over my screen" what do those look like? Try to be decriptive or post a picture of those with your question Adding images to an existing question
by
while playing games in fullscreen i have not seen any artifacting, but when on my desktop using apps like my browser, i sometimes see groups of small black squares all over my screen appearing for no more than a second or two before disappearing and reappearing somewhere else
by
@callumventer this "see groups of small black squares all over my screen" is usually a memory issue. It is possible that your games are a bit to emory intensive. I agree with @jayeff, let start by getting the newest drivers for your complete system.
by
@callumventer so updating the drivers worked?
by
Add a comment
Chosen Solution
@callumventer
How much ram is installed in the desktop?
Have you got the latest rtx 3090ti msi suprim x driver version 536.40 installed?
Did you mean a ROG STRIX Z690-E GAMING WIFI motherboard?
If so have you got the latest Version 2306.4.3.0 chipset drivers installed?
Score 1
2 Comments:
currently ive got 32 gb of ddr5 ram
i honestly dont think i do have the latest drivers. where can i get those
by
@callumventer
I linked the drivers in my comment above your last one. Click on the blue links
by
Add a comment
I'm curious if you have enough power for that card. You didn't mention your power supply, but Games can get pretty demanding at higher resolutions, (and even for a split second) can cause artifacting. I could also be a result of overclocking, or card overheating.
If you have a friend, etc. who has a similar system, consider swapping a different GPU or PSU.
4 Comments:
i have a 1000w psu and unfortunately i do not have any friends with a pc
by
that should be adequate. When you are in-game are you seeing the squares, or only on the desktop?
by
only on the desktop
by
hi everyone, i have done some in game testing and it seems temperature cannot be the issue, my gpu sits around 45-50 degrees while gaming.
by
Add a comment
Add your answer
Callum Venter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 170
