A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
44 Questions View all
What can I do to fix this thats not to expensive?
My tablet has a black screen at first I thought i broke it completely but it has a voice thing. I made a post on here before someone said it was a module or something and that I can fix it by doing repair but thats costy for me and I tried the thing where you hold it at an angle with a light and I do see my screen on my tablet but its so hard to navigate to the screen share thing. Is there any other way?
Add a comment
1 Answer
Most Helpful Answer
Hi @ackack
From your description it sounds like a backlight problem with the display.
Your choices are:
  • Use the flashlight to navigate through the tablet and enable the Smart View feature (which should be on the tablet) and use screen mirroring to view the display on a compatible TV.
  • Check for the problem on the systemboard by following the no display troubleshooting flowchart from the service manual.
  • If the flowchart tests are OK, the display is faulty so you have to replace it.
Here's the ifixit Samsung Galaxy Tab A (2019) Screen Replacement that may help.
Score 2
Add a comment
Add your answer
ACK! ACK! will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 44
