The Dell Latitude E5270 is part of the Latitude Exx70 laptop series released in 2016. The E5270 Laptop has a 12.5" display and comes with either an i5 or i7 Intel processor.
6 Questions View all
After a while it shows BOOT MENU PCI LAN REALTEK PXE B09 D00
FN+Power doesn`t work on my device. Tried the above to no avail.
System Test
LENOVO
3367AJ5
Thinkpad X131e
BIOS ver. G8ET66WW @1.5GHz
Test : Passed
Result: UME001000-UJ8BEK
It is still beeping
Thinking, option is to remove hard drive attach a cable & connect it to another PC to access files, if no other fix.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @contactemail,
If it shows BOOT MENU PCI LAN REALTEK PXE B09 D00 then it's trying to boot from a network drive, which unless it is normally connected via an Ethernet cable to a network server isn't there.
Make sure that the HDD is the 1st boot option in BIOS.
If there's no HDD being detected in BIOS then there's a problem with the HDD or the connection to the HDD.
If the HDD is detected in BIOS then there's a problem with the boot record (MBR or GPT partition) in the HDD as the motherboard can't "see" it so that it can boot from the OS in the HDD.
What OS is installed in the laptop?
Score 2
1 Comment:
Thanks for responding,
OS = Windows 10
played with it a little, managed to get into bios, changed boot sequence.
& so get PC/device, boot config data file does not contain valid info for operating system.
FILE:\Boot\BCD
ERROR CODE : 0xc0000098
USE RECOVERY TOOLS
THEN got this message.
Thermal sensing error
So might be up for a fan as well.
Ordered a boot disk.
by
Add a comment
Add your answer
Contact Email will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 195
