The Razer Blade 15" Base Model (2020) is a powerful gaming laptop, with a 10th gen, 6-core, 5.0 GHz Intel processor.
Adding USB-C charging option externally
I've seen some adapters around that connect to Razer's proprietary connector, and was wondering if anyone has attempted to use a USB-C PD board to charge the laptop? I mostly use my laptop portably in Linux without use of the discrete graphics so I only require <100W of power which USB-C can provide. But unsure whether the charging port will accept less than the 230W that comes from the regular charger
1 Comment:
Would love an update on this!
by
Add a comment
1 Answer
@lachlanhogan It depends how razer has their power management set up, with other brands such as Dell they force the CPU to throttle a huge amount if it's not connected to the correct power supply, either you'll get lucky or it won't be usable unfortunately.
Thanks! :)
Add a comment
Add your answer
Lachlan Hogan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 49
All Time: 879
