The Lenovo IdeaPad S340-15API is a versatile laptop offering a range of AMD processors, display options including 15.6" FHD or HD, and up to 12GB of memory, designed for both productivity and entertainment with various ports and connectivity features.
1 Questions View all
What kind of screwdriver is needed to remove the bottom cover
what kind of screwdriver is needed to remove the bottom cover
Add a comment
Most Helpful Answer
Hi @danilgogolenko
Here's an image taken from this teardown video that shows that the screw is a Torx screw.
(click on image)
The specifications for the 10 screws in the base as shown in the hardware maintenance manual (see p.34) are M2.0 x 6.5mm (9 screws) and M2.0 x 3.5mm (1 screw)
M2.0 = 2mm so that is about a T6 or T7 Torx screwdriver.
Score 1
Add a comment
According to this question, What screwdriver do I need to take off the lower (bottom) case of a and this question which screwdriver do I use? A T5 torx screwdriver is needed. The screw heads in the bottom cover of the Ideapad S340 are reported as being T5 torx screw heads by most users.
A quality small driver kit with several common bit sizes (torx T4,T5,T6, Philips, etc) can be handy; example: Minnow Driver Kit.
The Minnow pocket-size polymer driver and portable precision bit set is our smallest kit ever! 16 precision bits and a 4 mm driver for repair on the go. Image
Product
Minnow Driver Kit
$14.95
Score 1
Add a comment
Add your answer
Данил Гоголенко will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 416
