Repair and disassembly information for Google's Pixel 6 smartphone, released in October 2021. Identified by model number GB7N6 and G9S9B16.
58 Questions View all
All sensors failed after replacing display
This is after my second display replacement. First the audio was muting frequently for a second. It even happened for bluetooth. Then I noticed the proximity sensor failure and then gyroscope and rest. I have even removed and reinstalled the display. Did I miss any connection or my sensors were damaged somehow during the replacement? Pls help.
Add a comment
@mmhebron Hello! A little bit of a long shot, but have you tried factory resetting the phone? Sometimes replacing parts can cause very weird software issues which is what this is sounding like, it's likely to either be that or some form of motherboard damage.
4 Comments:
Yes, I forgot to mention that. I did reset and nothing has changed. After that I have removed the screen and installed again.
by
@mmhebron Ah, unfortunately then the most i can suggest is ensuring that all other connectors are properly seated and that none of the antennas are damaged or deformed!
by
Last night I have installed security update 5th August 2023 and everything is working fine. Phone resetting failed, but a 22mb security update fixed it. Wow Google, are you for real? 😒
by
@mmhebron Sounds like most tech companies to be honest.... glad it's sorted atleast!
by
Add a comment
I have been facing the exactly the same issue since yesterday. Hope next security update will fix this. Fingers crossed.
Add a comment
Add your answer
Moshe Hebron manukonda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 192
