How to open device?
How do I open the device? My cats knocked the projector off it's place holder and the focus doesn't work as it should. it seems like the lens was knocked out of its focus track and no longer spins unless I hold it for a long time. But it never gets the focus right. If I could get the body open, I could pop it back into place but I don't know where to start.
Thank you!
Score 2
2 Comments
@jayeff
Looks like they redesigned as I don't have those screws at the bottom nor the pieces he pulls out in the beginning of the video :(
by
How did you finally open it?? I have a similar issue with the lens, did you discovered what happen??
by
Add a comment
1 Answer
Chosen Solution
Hi @kennediehurt
Here's a video that may give you some clues as to how to open your projector.
I realize that is it not the same model, but mostly manufacturers don't alter things that much between models or if they do not often.
Worth a look perhaps anyway.
Score 3
2 Comments:
@jayeff
by
@kennediehurt
If the unit has rubber "feet" try removing them as sometimes there are screws underneath. Also check under any labels as they could also have recessed screws there.
Please unaccept my answer as it didn't fix your problem.
Cheers
by
Add a comment
Add your answer
Kennedie Hurt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 22
All Time: 123
