4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1055 Questions View all
Can I use an iPhone 6s battery on a SE?
So I have an almost complete iPhone SE 1 without a battery, that I am unsure if it is working or not, and I don’t have a SE 1 Battery In my spare parts bin, but I do have one of a 6S, I looked and the connectors are exactly the same, I know that the 6S battery is too big and won’t fit inside the phone, but I just want the logic board to be powered to see if it’s working. will it work? Will it brick the logic board if I connect it? or do I need an actual SE 1 battery?
2 Comments
@hazel_888 if you have a voltmeter you can try to check the voltage on the pins on both batteries. If they have similar voltage on the same pins it shouldn't harm the board.
by
Hold that thought. I'll check.
Just gotta find out which side is positive because the connectors are not in the same orientation.
by
Add a comment
Most Helpful Answer
Sure can. I had to check. But works with the SE. You just have to turn the battery perpendicular to the phone. The part of the battery connector that's close the the battery is the positive side.
Score 1
Add a comment
No, you can't the battery connecter can't be matched.
1 Comment:
Battery connector is the same though on the first gen SE and the 6S
by
Add a comment
Add your answer
Hazel will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 46
All Time: 367
