The Whirlpool WRS588FIHW is a 28 cu. ft. side-by-side refrigerator with a 17.6 cu. ft. refrigerator and a 10.4 cu. ft. freezer, featuring an EveryDropTM Water Filter dispenser, ice maker, smooth door style, and adjustable gallon door bins. Its dimensions are 36" W x 69 3/4" H x 36 1/4" D.
1 Questions View all
Why won’t my ice maker fill up with water to make ice?
We have had 3 repair technicians out to fix our ice maker. The ice maker slowly started to make less and less ice then it just stopped. We have figured out that the ice maker is not filling up with water. Now we do have a water dispenser also and it is working just fine. It is just the ice maker. Please help! We just got this refrigerator two years ago.
Add a comment
1 Answer
Most Helpful Answer
Hi @brandiegoddard
You never mentioned what the repair technicians did (or didn't do) to fix the problem?
Here's the tech sheet for the refrigerator that may help.
Enter the service diagnostic mode as described by the sheet and step to Test #45 Icemaker Water Fill test and check the results.
The dispenser and ice maker valves are a twin valve unit (example only to show image of valves unit)
It may be that the ice maker inlet valve is faulty or clogged up.
Whirlpool SXS Refrigerator Dual Secondary Water Inlet Valve - WPW10341320 Image
Product
$117.99
Score 1
Add a comment
Add your answer
Brandie Goddard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 28
All Time: 101
