Find repair and further information about the Maytag MFI2568AE* refrigerator, a bottom freezer model equipped with an ice dispenser, automatic defrost system, and an anti-sweat heater switch. This page covers information for model numbers matching the pattern MFI2568AE*.
3 Questions View all
no light on front controls and the lights out in the refrigaroter
have done everthing you have said the refrigaroter is still working just no light on front controls and the lights out in the refrigaroter is it the front control board are main control board model number is mfi2568aes Thanks
Add a comment
1 Answer
Most Helpful Answer
Hi @larrychilcutt
Just clarifying if the display still works on the control panel?
If it does try entering the service test mode as described on p.4 and then perform service tests #151, #152 & #153 as described on p.5 and check what happens.
If it doesn't then most likely the problem is on the main board as that is where all the relays that are operated/released to turn on lights etc are situated and also where the power is distributed from - see the schematic on p.1
Score 1
Add a comment
Add your answer
Larry Chilcutt will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 65
