Why is camera not turn ON
Camera not turning on
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 34
All Time: 246
4 Comments
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
by jayeff
Yes, I already checked it
by Priyeshcamera
Start problem not running
by Binod Saw
Camera is 1year old please recover
by Display is on but don't work
