My laptop motherboard is dead. Any option to repair it.
Hey Umer,
First, try testing your power input using a multimeter from the beginning to the end of the line. This will help determine if the power is the issue. If it is, you can fix it.
Next, check your CPU and hard drive to see if they are starting or powered on. You can also try testing them on another computer. If they are the problem, then that's the cause.
Thanks.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 205
