The Huawei P smart is an Android smartphone released in January 2019 by Huawei, a Chinese electronics manufacturer. It was released in 32 GB and 64 GB versions and includes hybrid Dual SIM capabilities.
19 Questions View all
Screen is coming away from body of phone, what adhesive to use?
My P Smarts screen is coming away on the top right corner. The screen itself appears undamaged. What type of adhesive should I use to reattach it? Also would I need to remove the screen and clean any current adhesive layers for this, or is simply applying a little bit of glue in the gap and applying some pressure enough?
Cheers.
Add a comment
1 Answer
Before doing anything, make sure your battery is fine, as a swollen battery is the most common reason for a popped screen.
1 Comment:
It's the end of the phone opposite the battery and there is a slight bit of damage to the actual casing of the phone on the same corner from when I dropped it ages ago so I think it's just the screen coming away as opposed to the battery being swollen. Battery life is still pretty good and it doesn't really get warm particularly. I'll check that when the time comes but regardless if the battery is damaged I'd replace it with a new one instead of getting a new phone anyway so some adhesive for the screen would still be needed.
by
Add a comment
Add your answer
OverlyFluffyDoge will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 36
All Time: 129
