The IKEA FIXA is a cordless power drill and screwdriver with an integrated 7.2 V Li-Ion battery.
1 Questions View all
Can I convert my 4.2 volt hand drill to use 5v or 12v DIRECTLY?
I have a 4.2 volt drill and the battery life is really annoying so can i replace battery with a 5 volt soldered input to directly power the drill, or could i use 12 volt to directly power the drill. Which one is more safe? Id like to challenge myself with this project. Are there any limitations. I just want it to work. i.e. : my device does not exist on ifixit site so ill attach an image.
1 Comment
The risk of using a 12v battery on a 4.2v small electric screwdriver may result in premature burnout of the motor from over voltage and current. Not advisable as this can shorten its life. Using a 5v source from a battery is safer and allows longer life as an external power source. Three 1.5 volt batteries adds up to 4.5 volts. A little higher if using rechargeable batteries. The physical size of batteries determines how long the power lasts.
by
Add a comment
1 Answer
Chosen Solution
To use 5vdc all you need to do is connect the battery and drill away. All battery device will usually handle as much as 3 VDC more than they are rated. As far as 12 vdc you will need to drop the voltage and the easiest way to do the is hard wire a cigarette lighter to cell phone adaptor inline between the battery and your device. I personally have modified the connections on many of my 18 VDC and some 14 VDC devices to connect to a 24 VDC pack I .ade and so far so good.
Score 2
Add a comment
Add your answer
KevVs will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 82
