The Husqvarna YTH20K46 is a 24-horsepower lawn tractor or riding lawnmower with a cutting width of 46 inches.
11 Questions View all
Mower won’t start, no click or spark. Maybe a safety/kill switch?
So, I started the mower up just fine and drove about 5 feet and it shutoff. I tried to start it again, and nothing. No noise or crank at all. So I bypassed the ignition with a flathead and it sounds good but just won’t get any spark. I took the fuel line off and fuel is coming out when attempting to start. However, the spark plugs have absolutely no spark at all. So I replaced them and nothing change.
To sum it up, turning the key does nothing. But I can bypass it with a flathead and it just cranks but gets no spark. Fuel system seems good, so I’m curious if there’s a safety/kill switch somewhere.
It has a new tank of gas, new spark plugs, fuel is spitting out, oil is new, filter isn’t clogged.
Add a comment
1 Answer
@jaredjones1556 here is the schematic for the mower you listed
First thing to check would be the seat kill switch and after that the wiring to the junction box and the ignition switch. To start, the ignition switch connects B + S + A1 so your clutch safety switch is right in the midst of it as well. Oh yes, check all of your fuses too.
Add a comment
Add your answer
Jared Jones will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 58
Past 30 Days: 355
All Time: 2,350
