The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
186 Questions View all
What is the difference between these two types of display?
To buy some spare parts I use an Italian site called "e-pol" (it is widely used in Italy and is reliable). I should buy a display for a samsung galaxy a12
and it gives me these two results. I noticed that there are two frame display versions: FLAT A125F and FLAT A022F. Can you tell me what is the difference between these two? Thank you.
Score 1
Add a comment
1 Answer
Chosen Solution
From what I can gather on my parts supplier's website, it appears that the Galaxy A12 and A02 will use the same or similar display panel meaning they can be interchanged. However the differences may lie in the frame the display is attached to as the devices have different internals.
Some suppliers will sell just the display panel itself or the panel already attached to a frame to make it easier to repair, you just have to swap the components. If this site is selling these displays with the screen attached to the frame, you may need to buy the first one. Or depending on their return policy, you could order one of each and see which one works and return the other.
Score 1
1 Comment:
Thank you very much, intuitively I was thinking it was something like that. Thanks for specifying, now I am sure to order the first one. In case there are any problems anyway, I can very well return it without any problems.
by
Add a comment
Add your answer
Gavino Santu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 137
