This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
321 Questions View all
DS Lite wont turn on. But having a GBA cartridge boots into GBA.
I'm not sure why but my DS Lite would shut off as soon I turned the console on with a white screen for 0.5(?) second. But for whatever reason, if I insert a GBA Cartridge into the system. It boots into the GBA cartridge. But wont work if there a GBA And a DS cartridge inserted at the same time. Is there some sort of fix?
Add a comment
1 Answer
Look's like your top screen ribbon cable has an issue, i had the same problem with three DS's , your lucky that your GBA cartridge is working because you left it on manual mode, you need too replace the top screen, unluckily there's no other solution
DS Lite Upper LCD Replacement
Add a comment
Add your answer
Bashy Bush will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 49
