How to check power socket
while powring on with wire its not showing power on anp pressing hard its getting charged
Hi @amitvirani
Here's the service manual for the laptop.
Go to p.79 to view the procedure to remove/replace the power adapter port.
You only have to dis-assemble the laptop far enough so that you can safely unplug the port's output cable from the motherboard.
Once that is done use an Ohmmeter (or a voltmeter), to prove continuity of the connection between the port input and the red and black wires on the cable plug on the output side of the port.
If the port is faulty it cannot be repaired. It has to be replaced.
Search online for KD4T9 to find suppliers that suit you best.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 72
