iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
Backlight shutting down randomly after gpu replacement
Hello together!
I have replaced the GPU due to a GPU error (no boot only in safe mode and then with horizontal stripes at the cursor).
Everything worked fine for a few hours, but now the backlight of the LCD goes off at random intervals (LCD works, but no backlight).
I now opened everything again and saw that the Vsync flex cable is damaged (pins broken) probably I was too rough during disassembly....
Can I now simply replace the cable and everything works again or is more defective?
If I do not connect the cable the error remains unfortunately...
Add a comment
1 Answer
I would start there, is the sockets damaged?
1 Comment:
No it seems to be okay
by
Add a comment
Add your answer
Valentino will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 43
