Released in January of 2021. Identified by model numbers SM-G996B, SM-G996B/DS, SM-G996U, SM-G996U1, SM-G996W, SM-G996N and SM-G9960.
27 Questions View all
Samsung Phone Vibrates But no Display
I recently replaced the battery in my S21+ phone, When i turned it on to charge it the screen was green and only half of the touchscreen worked. I could not turn it off but i took it apart and tried to reinsert the display cable now i am getting no display at all. Please
Add a comment
1 Answer
@conner592 "screen was green and only half of the touchscreen worked" sounds like a failed screen. Of course you checked your flex and your connector for any bend pins etc. If you find that all of those are okay, then the issue is most likely with the display. You'll have to change it and then re-evaluate. Easiest would have been to replace the screen/battery assembly.
Samsung Galaxy S21 Plus Screen and Battery Assembly Replacement
Add a comment
Add your answer
Conner592 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 16
All Time: 82
