Phone internal memory full
What should be the solution
Score 3
1 Comment
Saya juga mengalami ponsel perangkat penuh
by
Add a comment
Most Helpful Answer
Hi @adewuyiadebayo
To increase the storage in the phone insert a micro SD card (up to 512GB capacity) into the phone and then move your apps/personal data etc from the internal storage to the SD card.
Here's an image that shows how to insert/remove and format the SD card that may help.
(click on image)
Here's the user manual for the phone that may also help.
Score 2
Add a comment
My first suggestion is to delete any apps that you don't use. If that doesn't lower it, then go to your settings and navigate to battery and device care. Once inside, click on storage it will show you a breakdown of what is taking up most of your storage. Now, the next thing to do is start cleaning out your storage by going to each problem spot and start deleting any unnecessary files and/or apps. Hopes this helps!
Score 1
Add a comment
Clear unwanted and old files every 6month please do software reset
Add a comment
Add your answer
ADEWUYI ADEBAYO will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 608
