{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
208 Questions View all
Will MBP still work if Touch Bar is disconnected?
My MBP's Touch Bar started doing the blinking/flashing thing about 17 months ago. It got to the point where sometimes it would even stay off. I remapped the most essential functions to the physical keyboard, so not having a working Touch Bar didn't bother me too much. However, putting the MBP to sleep when the Touch Bar was off would cause the MBP to crash upon wake, at which point the Touch Bar would be on again. Strangely enough, restarting or shutting down did not do this - the Touch Bar stayed off. So I managed to keep the Touch Bar off for over a year by never putting my MBP to sleep - it was either on, or shut down.
Eventually, after a little over a year, the MBP randomly restarted itself in the middle of a sesson, and the Touch Bar turned on again. It worked fine for about 5 weeks, but now it's blinking/flashing again, and rapidly getting worse. Anyway, to avoid a costly repair, would it be possible just to leave the Touch Bar disconnected from the logic board? Or would it render the MBP unusable? Or maybe I can just let it blink itself to death, as long and annoying as the process will be?
Add a comment
1 Answer
Most Helpful Answer
Good question! Sadly I’m not sure😞 I’ve always replaced them which is a pain!
A good Mac repair person should be able to replace the TouchBar if that is the issue it’s Also possible the issue is the driver logic which is even easier to get to and replace but a bit more expensive a part.
Score 1
4 Comments:
Thanks for the reply! Unfortunately, according to another answer given in this forum, it is not possible to source a Touch Bar for the 2018 MBP, the only repair available is a full upper case replacement. If the repair was just a Touch Bar replacement, I'd probably do it, especially since I don't know if I trust myself to open up the MBP and disconnect the Touch Bar, so I'd probably pay someone even just to do that, if I knew it would work.
by
@jcchang - Here's the part for your system Touch Bar for MacBook Pro 13 Inch A1706 2016-2017 A1989 2018-2019 That is what I've used
by
Oh cool, I only looked at the part available here. Thanks!
by
A bit late..but I was informed by an apple authorised service person that the error is probably on the logic board or on the upper case....and that one of these needs to be replaced. He did not say anything about just replacing the touch bar itself. But maybe that only reflects how Apple works - i.e. even if it's only the touch bar that is broken they do not replace that alone but the whole cover. I would like to know how disconnect the Touch Bar physically - and if that would have any unwanted effects (will the start button work).
by
Add a comment
Add your answer
jcchang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 262
