{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
208 Questions View all
MacBook not starting after battery replacement
Replaced the battery on my 2018 Macbook Pro Touchbar, turned it on, and it started, Coconutbattery said it was at 100% battery health with 0 battery cycles. I took out the battery, used the adhesive strips to glue it in, and then put it back together. Now, when I try to start it, it shows no signs of life. I've tried reinstalling the battery several times, as well as starting the Macbook while plugged in. Is there anything else I could do? How else can I troubleshoot this issue? Thanks in advance :)
Add a comment
1 Answer
Did you forget to fully shut down the system the second time? Refer to Step 1 in this guide MacBook Pro 13" Touch Bar 2018 Battery Replacement
At this point you need to connect a second Mac via USB-C using Configurator2 App to recover things.
2 Comments:
Thanks for the response! It looks like I did forget to disable auto boot before doing the repair. Will I be able to get the Macbook working again? If so, how do I go about doing that. Thanks again!
by
@maximm65709 - You need to leverage a second system to run Confurator2 apps
by
Add a comment
Add your answer
Maxim M will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 75
