Repair, disassembly, and troubleshooting information for the second-generation Apple Watch SE, released September 2022.
8 Questions View all
Is Apple Watch SE replacement display compatible with Apple Watch SE 2
I have an Apple Watch SE 2 40mm and the display was damaged during an accidental drop. The display cracked around the perimeter and has popped out (leaving shards still adhered to the body).
I found the in-depth guide for replacing a damaged display for the Apple Watch SE, but nothing for the SE 2. It seems like removing the display is essentially the same process, but before I purchase the replacement part from ifixit I am curious if the display for sale on this website (Apple Watch SE 40mm) would be compatible with my SE 2? Does ifixit sell a replacement display specifically for the SE 2?
2 Comments
I think the LCD panel and the digitizer is the same between SE/5 and SE2, because the flex cable seems to be the same. The only thing I don’t know is the nfc circuit and the glass shape
by
I can confirm, after successful swap, that LCD and digitizer from SE/5 is fully compatibile with SE2022 (in my case taken from Watch 5). I only swapped the NFC from original screen to the new one.
by
Add a comment
1 Answer
Chosen Solution
Hi @azaadkb
ifixit does sell the Apple Watch (44 mm SE 2) Screen but unfortunately it is currently out of stock.
The Apple Watch (44 mm SE) Screen is not interchangeable with the SE2 screen
Check both links to see what model numbers are compatible with each screen. Scroll down to the item Description section on the right side of the page.
Apple Watch (44 mm SE) Screen Image
Product
$139.99
Apple Watch (44 mm SE 2) Screen Image
Product
$149.99
Score 3
3 Comments:
I think the LCD panel and the digitizer is the same between SE/5 and SE2, because the flex cable seems to be the same. The only thing I don’t know is the nfc circuit and the glass shape.
by
by
Dan you the man!!! thanks for that info, it’ll save a lot of people a lot of work
i’ll leave kind of “tags” so it shows if someone googles
watch SE 2022 2nd gen screen works with S5 SE
by
Add a comment
Add your answer
azaadkb will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 30
Past 30 Days: 186
All Time: 1,120
