A USB (Universal Serial Bus) cable is a common type of cable used to connect devices such as computers, smartphones, printers, cameras, and other electronics. It is designed to transfer data and power between devices, and is often used for charging devices as well.
15 Questions View all
Laptop cooling pad, usb fan cable end replacement
I'm trying to fix a laptop cooling pad. The usb end broke off. So I figured, easy fix, found a spare usb end and soldered the wires together. No dice. It's a 2 fan setup, I assume wired in parallel. It's not really designed to be taken apart, so I can't get a good look at the set up. Lable on the pad says it's rated at 5V 0.45A 2.25W. I tried a few power sources, each time I get 5V before connecting the fans, and 2V after. I tried just wiring one, and got the same. Seems like it should have been the simplest fix, but I'm stumped.
Attached is a pic with it just connected to one fan.
Add a comment
1 Answer
Chosen Solution
nvm :) I tried a few other usb donor cables and on the third one, it worked. So must have been something wrong with the donor usb connector.
Add a comment
Add your answer
Brandon “バーナビ” Barnes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 94
