The Land Rover Defender (initially called the Land Rover Ninety and Land Rover One Ten) is a British four-wheel drive off-road vehicle developed from the original Land Rover Series launched in June 1948.
5 Questions View all
Noise when clutch pedal is depress
Landrover defender 130 td5 after i have replace the clutch kit and thrustbearing when i depress the clutch pedal there is a noise sound like gears running with out oil but with the clutch pedal still depressed and selecting 2nd gear the noise go away but when i select any other gears the noise comes back even when in neutral but when i release the clutch pedal the noise is gone can it be something in the gearbox or the spigot bush that cause that noise. Thanks Max.
Score 1
Add a comment
1 Answer
Without more info on what kind of clutch system you have I would have to say you probably need to bleed the clutch system at the slave cylinder
1 Comment:
I have fitted a new clutch kit and thrustbearing a new clutch master cylinder and a new clutch slave cylinder the clutch have been bled about 3 times already but the noise stay there.
by
Add a comment
Add your answer
Max IRMSCHER will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 103
