Identified by back sticker and 67W charging.
12 Questions View all
Xiaomi 11t pro. Battery stuck at 15%
Hello, I have a problem with my Xiaomi 11T Pro. The phone froze at 15% battery charge. Neither a software update or a battery replacement helped. What could this be?
Score 6
6 Comments:
@oldturkey03 The phone works well, it charges correctly, but it always shows 15% battery charge, no matter if I discharge it or charge it. I also replaced the battery connectors, but it didn't help.
by
It's a hardware problem, I fixed it opening the phone and pressing the battery connectors
by
@ssss17468 this is the best answer, i already solved my problem
by
Exactly SSSS. even without opening. just press the 2 points where conectors are.
by
can i know the 2 points the @Luca?
by
Show 1 more comment
Add a comment
If the new battery didn't solve the problem, most likely the problem is at power management ic on motherboard. Also common issue of false battery percentage is a bad connector.
1 Comment:
I also have the same issue, my xiaomi 11t pro didnt increasing, but the overall performance of the phone is okay and smooth, just the battery concern stuck in 15%, i think the battery is need to replace a new one...
by
Add a comment
It same like mine after updating to HyperOS, I was thinking it because of update but after I go to store any said that I need to change the charging dock assembly to fix the ploblem!
Add a comment
Add your answer
Gustek will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 65
Past 30 Days: 207
All Time: 5,598
