swift one door is not getting auto locked
Only three doors are getting auto lock, one remain unlocked
Hi @vinod61596
Bit confused as you first said the door is not auto locking and then later you commented that the door is not opening, which is it?
Either way if you meant that the door power lock doesn't lock or doesn't unlock, but you can still manually open the door from the inside, then it could be a faulty power door lock actuator or a wiring problem from the body control module (BCM) to the door lock actuator.
Here's an image showing the wiring diagram for the power door locks.
Here's a video that shows how to remove the rear door panel so that access to the wiring in the door and also the door lock power actuator is possible.
(click on image)
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 90
All Time: 555
3 Comments
Hi @vinod61596,
What is the year model of the vehicle and which door is the door lock not working correctly?
by jayeff
2012 swift , back door not opening
by VINOD
A/c compressor notworking
by Kichuz Achuz
