Released in October 2008, the Dell OptiPlex 760 SFF is the small form factor model in Dell's OptiPlex 760 lineup. It is relatively simple to open and repair.
4 Questions View all
Load up problem in my pc when I try to go in to windows it says failed
it says failed to open then it take me to the screen where it says strike the F1 key to continue, F2 to run the setup utility Press F5 to run on board diagnostics, and when i try to run the diagnostics it starts and then stay ate 5% for memory testing
Add a comment
1 Answer
Are you using a “real” copy of Windows or, a “bootlegged” copy. Reload Windows. If the problem persists, do a clean reload.
# Make a DOS boot disk with format and fdisk on it.
  1. Boot from the floppy and run fdisk /u /r.
  2. Run format c:/ /s
  3. Boot from the HDD and load Windows.
Add a comment
Add your answer
ClagsYT will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 59
