A 10 speed mixer made by KitchenAid in 2006.
29 Questions View all
Why does my mixer not turn on until I place it on the highest speeds?
I am not happy with my mixer. First off, it cost a lot of money. Second, the top does not tilt backwards which makes adding ingredients very difficult. Over the years, I’ve gotten used to that only because I don’t use it a ton (usually only around the holidays). Now the problem is it will not turn on until I set it to the highest speed and I boy, that makes quite the mess especially with wet ingredients. It will go to normal speed once I turn it back down. I have switched places on my counter to try different outlets and that’s not working. Any idea what could be wrong? I have had the mixer for several years but as said earlier, I’m not using it a lot so I don’t understand what happened?
Add a comment
1 Answer
Most Helpful Answer
Hi @tara85663
Regarding the "does not tilt backwards" problem, check if the neck pin adjustment is OK. Here's a video that may help.
With the speed problem, it may be a faulty speed selector switch or board. Here's the ifixit KitchenAid Professional 600 Speed Selector Replacement guide that shows how to replace it.
Search online for KitchenAid Professional 600 Speed Selector to find suppliers that suit you best.
Score 2
1 Comment:
I don’t think this model has a tilt back feature. But that’s ok. I’ll look into the speed selector replacement. Thank you!
by
Add a comment
Add your answer
Tara will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 81
