Repair information for the HP Pavilion dv7-6163us laptop. It was released in 2008.
Shuts off unless it's plugged in but says the battery is fully charged
I bought a new battery for this a couple months ago and it worked fine until a few weeks ago. Now it can only stay powered on if it's plugged in despite the battery saying it's fully charged. I never had any issues with this until now, I didn't leave it on the charger all the time, and did nothing different from the months prior.
I tried taking the battery out and restarting it, I dusted the ports (but can't get the case off due to 3 stubborn and now stripped screws...) I don't know what else to do or how this even happened. Any other ideas?
1 Comment
Does it fade out when it shuts itself off, does it shut down, or does it just cut out?
by
Add a comment
1 Answer
Chosen Solution
Hi @pandabear4087
Create a battery report to check the charge status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value.
For a good, new battery, the values should be nearly the same.
If the Full Charge Capacity value is <30% of the Design Capacity then the battery maybe cannot handle the load and it is failing or has failed.
Score 1
Add a comment
Add your answer
Panda bear will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 103
