Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
52 Questions View all
Can the digitizer cable in the display be repaired/replaced?
When opening the computer to replace the battery, I ended up damaging the digitizer cable on the LCD screen. Any way this can be fixed or replaced?
Screen works perfectly, lost the touch screen functionality though :(
Add a comment
1 Answer
Most Helpful Answer
I'm so sorry this happend! It looks as if the display cable is part of the display. Try pulling gently up on it, and if it doesn't work, I think you will need a new display. You might be able to find a cable somewere and solder it, but that would be very hard, if possable.
Score 1
2 Comments:
I appreciate your suggestions. Replacing it does seem like the best option, as attempting to solder without the right equipment can be very challenging. Unfortunately, I don't have access to a microscope. I'll look into getting a replacement display and hope that resolves the issue. Thanks again for your help!
by
@soryn no problem! Glad I could help.
by
Add a comment
Add your answer
Soryn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 58
