Broken Solder Pads, where do I run the jumper cables?
The solder pads of the right shoulder button came off. I saw online that I can run some cables to fix it or scrape a little bit of the green covering. But I don't understand the trace and where should I connect the pads too, both the three pointing downwards and the ones on the side. Can you help me?
Add a comment
