2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
Why does my bootcamp assistant not show this option?
When following the tutorial to install windows 10 in my 2014 macbook pro i7, I opened the bootcamp assistant app and then was going to choose the windows iso but I looked at the video and then looked at my mac and saw a completely different screen showing (SELECT TASKS) instead of choose ISO file. If anyone can help that would be great!!
Add a comment
1 Answer
Chosen Solution
The reason for the Select Tasks page showing up versus what was shown in the YouTube tutorial you found is that your Mac does not support installing windows without creating a USB installer from the Windows ISO which is available on the 2015 and newer Macs. Basically you will need to select all three of the available tasks to continue and you will need an 8GB or larger flash drive. The following step will have you create the bootable flash drive and select the Windows ISO. After the USB drive is created then it will allow you to partition the internal drive for the Windows installation. For a detailed step by step please see Apple's support document here.
Score 1
1 Comment:
Thank you It helped (:
by
Add a comment
Add your answer
Chase reitelbach will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 38
All Time: 120
