The laptop doesn't on even the charger is connect with it
The laptop doesn't on even the charger is connected its power button light on or a second and then turn off
@kamilshah start with the basics for the troubleshooting like you will with any other device.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you need to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see Adding images to an existing question
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Connect and external monitor and see if that shows anything different when your laptop starts up.
An on then off power LED normally would indicate a serious short on the motherboard. When mine did that, it was the CPU.
However, there are other devices that would cause the same thing. Start by disconnecting anything that plugs in. Lastly, the CPU.
If it powers on and the light stays on, that was it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 52
