Green tint on screen after powering on
I recently got a 2015 MacBook Pro for cheap,
everything was working fine the first five days, after that I noticed a green tint on the display.
This only occurs if the display has been off for about 40 minutes or more and it seems to get worse in cold environments, I've tested to see if this issue happens in hot weather and it becomes not noticeable or not existent.
Even in cold weather the display goes back to normal after 20 minutes of it being turned on. If facing directly at the screen the tint is barely noticeable, at an angle it's pretty visible.
Also ran Apple Diagnostics and everything came back with no errors. Opened up the machine and it has no signs of liquid damage.
These two images were taken after being inside a room with the AC turned on during the night and the computer being off.
I know the Retina Displays for this model of MacBook are expensive, I would like to try any other posible solution before having to buy a new screen.
2 Comments
Got the same issue after almost 9 years. Probably it comes with our screen cleaning behaviors
by chamara gamage
And you are also right about the tempreture around. When it is hot around, this does not come. What I do is when it is cold around, I keep the MBP close to my table lamp. That helps.
by chamara gamage
