Released in December 2017, Business focused laptops with, 8th Gen Intel processors.
6 Questions View all
POST Error hp The system has detected that a cooling fan is not oper
POST Error
hp
The system has detected that a cooling fan is not operating correctly.
Continued operation is not recommended and may cause unpredictable behavior that could result in random shutdown, data loss or possible system damage. The system will shut down in 15 seconds. To prevent shutdown and continue operation, press the enter key now.
System Fan (90B)
For more information, please visit: www.hp.com/go/techcenter/startup
Score 2
Add a comment
Most Helpful Answer
Hi @mdtaufiqur91852
Perhaps the fan is faulty or the exhaust vent is clogged with dust etc.
Can you hear if the laptop's fan is operating OK or feel the hot air coming out of the exhaust vent on the left side of the laptop?
Here's the maintenance and service guide for the laptop.
Go to p.62 to view the procedure to remove/replace the fan.
This will give you access to the fan so that you can check if it is dusty etc and needs to be cleaned or if it is faulty to replace it.
If you need to replace it, search online for L00843-001 to find suppliers that suit you best
Score 1
Add a comment
Hp sells parts online you can order or u can buy off eBay http://h10032.www1.hp.com/ctg/Manual/c05... that’s the Manuel you can also https://www.ebay.com/itm/314734746944?mk... buy this new fan it’s 11 bucks hp probably charges more but the service manual will have parts number for you to order from hp but to bypass all that I found the part you need and you can also make sure to replace the thermal paste also since you gonna take it apart anyways I’m sure that thermal paste from factory probably dried by now but hope this helps
1 Comment:
And if you gonna put new thermal paste buy this ARCTIC MX-4 (incl. Spatula, 4 g) - Premium Performance Thermal Paste for all processors (CPU, GPU - PC, PS4, XBOX), very high thermal conductivity, long durability, safe application, CPU Thermal Paste https://a.co/d/4QgkVIC
by
Add a comment
Add your answer
Md. Taufiqur Rahaman Prince will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 233
