The Kenmore Elite HE3 is a washing machine by Kenmore.
665 Questions View all
intermittent f6 code flashing on display.
Hello,
I get a f06 code on the washer when I run a complete wash cycle. I can usually run a rinse and drain cycle. I read the f06 post and tried unplugging and replugging various connectors on the CCU and MCU. I suspect a failing part, possibly a speed or rotation sensor. Where are these sensors?
9 Comments:
Hi @mron,
What is the model number of the washer?
by
It's an elite quiet pack 4
by
@mron
The model number would help to ensure that if parts are required that the correct part can be found.
by
110 45972400
by
110 45972400
by
Show 4 more comments
Add a comment
1 Answer
This answer was originally to another question.
Hi @mron
There is no balance sensor in the washer. At least there's none shown in the parts list for the washer.
Intermittent problems can be hard to find so perhaps try checking the connections between the MCU and the drive motor to see if they're all OK i.e. not loose, corroded etc.
Here's the tech sheet for the washer that may also help. On p.8 it describes how to check the windings for the motor, just in case one winding is not within spec or is on the limit of what may be acceptable to the MCU.
1 Comment:
The tech sheet is very helpful! thanks
by
Add a comment
Add your answer
Ron Moreland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 75
