The Dell Latitude 5320 is a 13.3-inch business laptop available as a standard model or a 2-in-1, typically featuring an 11th Gen Intel Core processor, integrated Intel Iris Xe graphics, 16GB of RAM, and a 256GB or 512GB NVMe SSD.
How to adjust hinge?
Laptop hinge has been getting looser over the past 1.5 years. Have not attached anything to the back of the laptop such as to add weight to the display which hinges. Need a guide which shows what screws(if any) to tighten.
Add a comment
1 Answer
Chosen Solution
Hi @gyratinghe82445
Here's the service manual for the laptop that will help.
Go to the bottom of p.49 to view the procedure to remove the display assembly. This will allow you to check the hinge screws that are screwed into the screw mount in the base enclosure (see images 5 & 6 p.50-p.51).
On p.68 it shows how to remove the hinges from the lid cover.
Score 1
Add a comment
Add your answer
Gyrating_Helicopter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 305
