Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
47 Questions View all
Replaced battery and screen adhesive but screen still pops up
Hi, I originally bought a screen replacement which went mostly ok, but I damaged the battery so also got a battery replacement. When doing the repair, I got the proper Tesa tape from this site, removed all the old glue and tape, and kept the watch closed with rubber bands for 24 hours. The watch works great, no issues at all but when I have it on and using it the screen slowly pops up. I'm not sure if it's a battery swelling issue or just an adhesive issue. I don't want to seal it up and cause some more serious damage, but also don't want to buy another battery and open it all up again risking damaging anything else. Any thoughts? Attaching two photos, one with no pressure on it showing the screen slightly raised, and the other when I squeeze it and where I think the screen should be.
Score 1
Add a comment
Chosen Solution
Try warming up the screen using a heater. If it feels warm, tie it again with a rubber band so that the glue spreads evenly
Score 2
5 Comments:
I used this Apple Watch (44 mm Series 6) Adhesive Strip but I'm considering a glue instead. It seems like there's a lot of recommended options like T-7000 T-8000 B-7000. Any specific recommendations?
by
[code]I often use the B-7000. .. it can be tried[/code]
by
by
I got some B-7000 and it worked perfectly! Kept it in a rubber band for 48 hrs and there have been no issues so far. Thanks!!
by
sama sama semoga hari mu menyengangkan
by
Add a comment
The replacement battery kit came with two gaskets/spacers with adhesive. But the adhesive (pre-applied to gasket) was useless - not very sticky. The watch would not stay together. Heating the watch and pressing it together was no help.
What did work was to clean the gasket and watch faces with some 99% isopropyl alcohol, then use B-7000 multi-purpose adhesive as mentioned above. Let it set for 24 hours with clamping pressure applied to watch. I've worn the watch for 5 days so far and keep checking to see if the face is loosening up. So far no problems.
Add a comment
Add your answer
Melina Jefferson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 35
All Time: 152
