Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
49 Questions View all
Will only start and run if I goose the primer bulb. As soon as I stop
Ive replaced a few of the gas lines and put on a new spark plug. It will start and run if i goose the primer bulb really fast,but as soon as i stop it dies.
Score 1
Add a comment
1 Answer
Chosen Solution
@danieltols68043 sounds like you are having trouble with the needle valve in your bowl. You may have fuel in there but it may not get through your carb. Remove the bowl, set the float height and check the needle valve. To check and work on your carburetor, use this guide Briggs and Stratton Carb Overhaul
Score 1
4 Comments:
Thanks I'll try that. I just ordered a new primer bulb as well.
by
@danieltols68043 sounds good. Let us know how it all works out.
by
Ok i will. Make take a week before i can actually get to it.
by
@danieltols68043 no rush, there is no time limit. We'll be here :-)
by
Add a comment
Add your answer
Daniel Tolson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 71
