Sony Alpha a6400 / ILCE-6400.
4 Questions View all
fried camera after using wrong plug in dummy battery
First off this is a Sony a6300 not 6400
I fried it when I was using a dummy battery, because the dummy battery came with 2 USB ports for power, I had to use a USB to power but it kept making a buzzing noises and thought it was strange so found a power point with the same connecter and fried it... I know very stupid of me and wasn't thinking
So my questions are
1) is the main logic board that needs replacing or can it be something else?
2) can i use parts from a a6000 or a6400?
Add a comment
1 Answer
Chosen Solution
Hi @nicholas69637
The main board in the camera (SY1066 board - Sony part #A-2119-197-A) where the battery management IC is mounted, assuming this is the affected component, has a different part number to the the main board used in the A6400 (SY-1094 board - Sony part # A5001624A) and the main board used in the A6000 (SY-1028 board - Sony part # A-2038-810-A), so presumably they're not interchangeable with each other.
Here's the A6300 service manual that may help with the disassembly etc.
If you wish to replace the main board, search online for A-2119-197-A to find suppliers that suit you best.
Score 2
Add a comment
Add your answer
Nicholas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 55
All Time: 278
