The Samsung Galaxy A53 5G Is a Mid-Tier phone released by Samsung on March 17, 2021
29 Questions View all
phone still vibrates when plugged in but screen is completely black
the phone recently dropped and fell completely faced down, and while there are absolutely no visible cracks on the screen- the phone is unresponsive- the screen shows no visuals at all- when someone calls the phone, you're able to still answer it if you press the area where the call answer button normally is (basically the touchscreen still works) and the phone vibrates when powering off, or plugging it into a charger
there is some damage on the back cover of the phone- it has a crack on it, and since the plastic is so thin, if you were to pry it a bit more- you could basically see the interals
is there a repair for this?
Add a comment
1 Answer
Hi @nanineko
Most likely there is non-visible, internal damage to the AMOLED screen.
Replace the display assembly and check if that resolves the problem.
Below are the Samsung part numbers for the different coloured display assemblies used in the model. Search online for the part number only, applicable to the colour housing of your model to find suppliers that suit you best.
black - GH82-28025A GH82-28024A
white - GH82-28025B GH82-28024B
light blue - GH82-28025C GH82-28024C
peach - GH82-28025D GH82-28024D
Add a comment
Add your answer
NaniNeko will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 64
All Time: 504
