Laptop will not charge with Lenovo supplied power adapter.
Laptop will not charge with Lenovo power adapter or any other USB-C power source I have tried. When plugged into power the light adjacent to the power port flashes (amber color) every 2-3 seconds. Laptop worked fine yesterday. I suspect a bad power port on the laptop. Is there any way to confirm this?
SOLVED: I opened the back and removed the battery. It still would not boot when plugged into the power adapter, I reconnected the battery, replaced the back and the problem was fixed. It's charging normally now.
Score 1
Add a comment
1 Answer
Chosen Solution
Score 1
1 Comment:
The fix above did not last very long and it eventually stopped charging again. After some back and forth with Lenovo tech support it was decided that I needed a new motherboard. I sent it back to them and had it repaired. Now the laptop charges normally but I have a new problem. It is often reluctant to awake from sleep mode. I have disabled all sleep settings and continue to have this problem. But this is a topic for a new post...
by
Add a comment
Add your answer
David Pinals will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 107
