Repair guides and support for your Sanyo TV.
358 Questions View all
Jack has been broken off the back am I. Able to use the HDMI or anothe
I'll ask again, I have a Sonia TV. I have antenna. Jack has been broken off the back am I. Able to use the HDMI or another Jack to hook up outside antenna.
Add a comment
1 Answer
Most Helpful Answer
Hi @dallasdhann
You would need to connect a pvr or set top box between the antenna and the TV i.e. TV antenna → pvr/stb → HDMI to TV.
You would then need to use the pvr/stb remote unit to change channels. Th eTV remote would be used to turn on/off the TV and volume control and any other TV settings etc if required.
The pvr/stb (example only to show what I mean) would have the digital tuner which is necessary to convert the over-the-air TV signals to a digital HDMI signal for the TV
Score 2
Add a comment
Add your answer
Dallas D Hann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 26
