Released on September 24th 2021, the iPhone 13 mini is a smaller version of Apple's iPhone 13 and is the second mini iPhone. It features a 5.4-inch OLED, an A15 Bionic processor, and dual rear cameras.
35 Questions View all
What did I do wrong when opening my phone?
I tried to follow the battery replacement guide, I heated up the adhesive and tried to gently take my screen off and this happened:
The upper ribbon that is supposed to be attached to the screen isn’t…
Is there a way to fix it or do I ruined my screen and need a new one?
Add a comment
1 Answer
Chosen Solution
The wrong adhesive separated, now the panel is torn off the frame.
The screen is ruined, you need a new one.
Score 2
5 Comments:
Thanks. And for next time - how can I avoid it? I followed the guide and heated the edge, nothing special I believe.
by
@tomavitan I can't speak for your specific case, but most of the time when we've seen this happen it's been because they forgot to remove the Pentalobe screws as the first step.
by
@dadibrokeit not in my case…
by
@tomavitan If you did remove the screws, usually it's because the screen was not original and the adhesive used to hold the panel and the frame together wasn't strong enough, or some corrosion happened and weakened that adhesive, or just pure bad luck that caused that adhesive to break first.
by
@tomchai Sounds like either I heated too much that area or just real bad luck. Thanks!
by
Add a comment
Add your answer
Tom Avitan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 94
