Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
107 Questions View all
Why my MacBook a2179 middle 2020 go to sleep 52-53% charge with
Battery is normal condition
86% left
Just went to sleep and shut down 52% charge with
Once it plugged it started with 52-53%
Look likes zero level is 52%
What can I do ?
Обновить (12/02/23)
It should be there
Add a comment
1 Answer
Most Helpful Answer
Hi @sergocappuccini
Don't know Mac that well but perhaps check the condition of the battery to see what it shows.
Score 1
6 Comments:
@sergocappuccini - To add to @jayeff answer install this Gem of an App CoconutBattery take a snapshot of the apps main window and paste it here for us to see.
by
@sergocappuccini - The battery looks healthy enough, but the charger is not connected so we don’t know if it can take the full charge. Shut the system down an let it charge over night a good 8 hours, the do another capture and post it here again.
by
@danj
It can’t take full charge
As battery’s health less 100%
Regard coconut it takes 93% maximum
Upd
I d cleared emc using 4 famous buttons
Then charge it till 100%
Then not unplugged it all night
Then unplugged it and try to reach 1%
However near 30% MacBook went to sleep
I d ones more charged it as full
as it can
Mac showed 100% but coconut 93% only
Ones it reached 100% i unplugged it and went down
It went sleep mode 1% with
I d again charged till 100%
and after been unplugged it reached 1% again
Bear in my mind trouble was solved
Have no idea how long it works
Thanks guys
by
@sergocappuccini - Can you post another snapshot with the charger plugged in that shows both the OS info and CoconutBattery when they conflict. Make sure you give both enough time to settle in as there is a bit of a delay between the two.
by
@danj I can’t post this info cause trouble was fixed now
So I can’t catch this screens
by
Show 1 more comment
Add a comment
Add your answer
sergo cappuccini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 65
