The DeLonghi ESAM family of products is a line of automatic coffee machines for making lattes, cappuccinos, espressos, and other drinks. Look for the model number ESAMxxxx on a sticker on the back or bottom of the device.
Coffee Machine Water leak
Water leak under machine when making coffee!
Add a comment
1 Answer
Most Helpful Answer
Hi @jacciv
Here's the ifixit DeLonghi ESAM xxxx Solenoid Replacement guide that may help.
Use the guide to disassemble the coffee maker so that you can check where the water may be leaking from e.g split pipe or loose fitting etc.
Score 1
Add a comment
Add your answer
Jacci V will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 133
